people
i created a wedlment assy with 2 parts that the material is specified as steel
i call this weldment assy into a upper assy and the material is specified as wedlment aluminum 6061
i go to material used in document i see the welded aluminum i see also steel but doesnt allow me to
assign to selelction. dont even know why a material is specified in a assy but i guess you have different material configurations for the same assy
anyway how do i change that so it displays in my partlists
Solved by blair. Go to Solution.
Or, use the same template, create a material called N/A or VARIOUS, and assign it to the Welds.
(Just another suggestion. I prefer to have the minimum amount of templates to choose from. Thanks Blair for directing me to the solution.)
