Inventor Forum
welding pin in hole
59 REPLIES 59
Message 1 of 60
inventorguy
843 Views, 59 Replies
welding pin in hole
having trouble welding again today... i have a round pin sticking out of a round hole of a plate and i would like to do a fillet weld around the pin to the plate... however... the hole is bigger than the pin so to my knowledge i have to fill the gap first with a groove weld but when i try that it only fills like half way around or gives an error... i click groove weld... click the cylendrical hole surface... click the cylendrical pin surface and click an edge that is perpendicular to these surfaces as the fill direction... am i doing it wrong? i even tried "full face weld"
59 REPLIES 59
Message 41 of 60
inventorguy
in reply to: inventorguy
i finally figured it out... using like 10 steps
Message 42 of 60
inventorguy
these are the different steps
Message 43 of 60
inventorguy
here it is finished
Message 44 of 60
inventorguy
so that was just a couple test pieces i was try to figure out... let me see if i can do this in my actual assembly...
Message 45 of 60
dxpal
I was able to replicate the example provided, but I still don't understand the theory in why it works this way.
Change the workplane split location......
Message 46 of 60
You could have saved yourself a LOT of time and trouble
by:
1. Posting the Inventor version used. We cannot read your
mind, not can someone post a solution in your version without that info. ( I do
not have R10 installed on my system any longer.)
2. Posting the actual files.
3. Posting your test files earlier.
In your test files, I see several things not needed, ie; the
splits on both parts. Not needed. Remove them and associated work
features.
1. The pin is exactly the length of the plate's thickness. Why
would you do this in real life? Make the pin longer.
2. Split the pin only, AROUND the circular face, so that it
has a face .02 longer than the plate thickness. Constrain the pin flush to one
side of the face. (Mate/Flush or your original Insert constraint
works.
3. Proper Pick sequence and settings are attached. Filean
result - next reply.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Message 47 of 60
Finished result.
Expert
Expert.
PcCillin AV
XP
Message 48 of 60
inventorguy
u dont have to read my mind... i posted the version of inventor i was using in post number 2... 3rd post from the top... in my real assembly my pin is longer very similar to the examples u were posting... out of frustration i was trying to figure it out using simple methods hints the pin/plate being the same thickness... ive tried it with no splits... tried it with the pin split only and the plate split only... and out of frustration tried splitting them both... still no luck... but that just happened to be the one i posted... was finally successful doing it a way seeming to be much harder than should be needed but doing it that way i used no splits... go figure... but ill take a look at doing it with a split a hair bigger than the part as u suggested... it might be a while because i have a meeting...
Message 49 of 60
Here's a sample made in Inventor 9 that will open on your
system.
Expert
Expert.
PcCillin AV
XP
Message 50 of 60
Here's how to do it.
Expert
Expert.
PcCillin AV
XP
Message 51 of 60
I'm not sure why a split the "exact" size of the plate
thickness noes not work either. However this is the technique that will work
with R10-IV2009.
Expert
Expert.
PcCillin AV
XP
Message 52 of 60
inventorguy
seems like ur instructions were pretty simple and clear but as i try them i just cant get it... see my attachment... i have given every detail of what i did but i forgot a few things... i used insert... they are both separate parts... in a weldment... using insert... the pin is .5 inch... the hole is .75 inch... the plate was extruded from a sketch including the hole... in sheet metal... the bar is extruded from a circle as a regular part feature... i cant see what im doing different than u? Edited by: inventorguy on Jan 2, 2009 7:14 PM
Message 53 of 60
I created my last test files in Inventor 9 (not 2009).
Did you open them and try that set? I then tested them in Release
11.
If my set fails, then make sure that you have ALL service
packs installed for version 10. Help > About Autodesk Inventor - should
reveal the service pack level you are at.
Expert
Expert.
PcCillin AV
XP
Message 54 of 60
inventorguy
ok... ur parts worked great... like magic after all this time... i tried to remake ur parts exactly as u did... works like magic... tried resizing the hole to a smaller size... .75 inches to match my example... works like magic leaving only one possible explanation... which is that inventor can not do this if the plate was made using the sheet metal feature do u agree? could u try ur same example using sheet metal?
Message 55 of 60
It's not magic.
Post your parts and assembly, zipped.
Expert
Expert.
PcCillin AV
XP
Message 56 of 60
inventorguy
ok... so i went to get the files to send it to you... and thought id try one last time to make sure it wasnt working... and like magic it now works on the sheet metal part... i dont understand? i didnt do anything different than i did before? if u remember this was my origional post... but then discovered i had used the wrong part and the part i was supposed to use was the same size (pin/hole) and therefore i actually had no gap to fill... however i continued wanting to learn this technique because i do have some round parts and gaps that do need to be filled... and they are acting very similar to the pin/hole problems i was having and i figured that if i could figure out the pin hole problem then i could figure these out too... but after all this... things seem to be working like magic... and im not sure why they just work all the sudden... and without knowing what i did to make it work... i cant make this work either... so im attaching it and heading home til monday soon... i have a feeling this will be a tad trickier than the pin/hole... although i have not tried spliting the faces of these objects like we did before... perhaps thats all i need to do? u helped me make this "shell" its sheet metal... its a circle... very slightly broken... then using contour flange it was created... the "bowl" was created as a regular part... using a revolved sketch... what i need is a big beautiful weld that can be seen from the bottom as in on the outside not the inside... the bead size is .07 inches... this is only a visual thing so any preps are fair game but changing the part is not... for example making the bowl bigger... i need the flat pattern of the shell so making it a regular solid extrusion or revolution is not acceptable... i figure the first step to making this happen is a groove weld to fill the gap in the "shell/bowl"
Message 57 of 60
inventorguy
shell
Message 58 of 60
inventorguy
assembly
Message 59 of 60
JDMather
You might refer to this book http://www.amazon.com/gp/product/0470293144?ie=UTF8&tag=mc02c-20&linkCode=as2&camp=1789&creative=9325&creativeASIN=0470293144
pg 289 Fig 10.32 & 10.33
And of course the "bowl" will not return a flat pattern.
Message 60 of 60
JoyceZhou
Hi, currently the workflow for such condition is to create Groove Weld to fill the gap first, then create Fillet weld
The issue to simple the workflow is a known issue, and has been added to our quality database.
PS: I would suggest you add all your inventor files in one ZIP file and attach it the next time if necessary:)
Joyce Zhou(Autodesk QA)
Joyce-Jinghua Zhou
Inventor QA Engineer
