Inventor Forum
volume
3 REPLIES 3
sam__gleeson
455 Views, 3 Replies
volume
Hi
How can i work out the internal volume of the cylinder attached
Sam
3 REPLIES 3
JDMather
in reply to: sam__gleeson
Drag red End of Part marker back above Delete Face to get back to original.  (see attached)
another technique is to Derive Component the original so that you can have both conditions at the same time.
sam__gleeson
than you JD Mather
1.  where can i then view the volume inside this cylinder.Is there a dialogue box in the tabs which gives the volume inside such as how many litres this cylinder will hold
2.  Could you please post a example of Derive Component the original so that you can have both conditions at the same time..another technique for me to learn
Thanks for help
Sam
t
JDMather
Check iProperties for the volume.
See attached for Derived Component method.
Right click on the top node of the browser to find iProperties.
