strange that one day this problem came - don't think i changed something...see picture attached please, some lines disappeared, any suggestions? thanks!
Solved by 4donwan4. Go to Solution.
Check your View Display Option is Inventor, are you on Shaded or Realistic? Did you somehow change to a wire-frame mode. Also check in your Application Options>Hardware>Performance, Quality or Compatibility settings.
You might try a good old system reboot as well. You can also check for the latest Microsoft Certified graphics card drivers for your card. Possibly your drivers might have been updated in a Microsoft update.
I would agree with previous post and what the elite member stated. This might be a video issue. Also consider installing update 3 for 2014 SP1.
Update 3 for 2014 SP1
2014 SP1 Update 3
Inventor Certified Video Card Drivers
Inventor Certification Site
Don
