Inventor General
Valued Contributor
Message 1 of 7 (171 Views)
Accepted Solution
view representations
171 Views, 6 Replies
05-03-2012 07:59 AM
In regards to assemblies:My small assembly contains about 30 separate parts and all in a dark blue color.I want to make the same assembly the color Green and another the color Black.
Do i follow the following steps
1. Do i RMB on View:Master and select NEW
2. Select all the parts and change to desired color
Have i missed anything
Regards
Simon,
Inventor 2012
*Expert Elite*
Message 2 of 7 (154 Views)
Re: view representations
05-03-2012 12:28 PM in reply to: simon_toaldo
Make sure it is design view representations you are using and NOT level of detail.
Make sure the new rep is active when you select the parts to colour.
Then make another new rep, set active and change the colours again.
You need to have one rep for each colour.
You can also rename the rep to match the colour for ease of recognition.
These reps can then be selected in higher assemblies to give the colour you choose, you will also need reps in the higher assembly to hold the chosen colour rep.
Drawings also use the reps for views and for driving part list filters.
*Expert Elite*
mcgyvr
Message 3 of 7 (150 Views)
05-03-2012 02:02 PM in reply to: harco
Really it depends.. Should each color variation of each part have a separate part number?
Or is the whole assembly painted after it is all assembled?
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2014 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Contributor
Message 4 of 7 (131 Views)
05-04-2012 07:13 AM in reply to: mcgyvr
I made up a quick example of a assembly and created 1 in Blue and 1 in Black.I named 1 view as Blue and 1 view as Black...I just then select the color view i want and activate and the color works.If this is the correct way you explained then i can go ahead and do this to my assemblies
Regards
Simon
*Expert Elite*
mcgyvr
Message 5 of 7 (124 Views)
05-04-2012 07:26 AM in reply to: simon_toaldo
You didn't answer these questions
1-Should each color variation of each part have a separate part number?
2-Or is the whole assembly painted after it is all assembled?
Nevermind.. I see you are a student and buying/stocking/inventory is probably not a concern of yours.. So then yes.. The example you posted is correct for this situation.
Windows 7 64 bit
Valued Contributor
Message 6 of 7 (120 Views)
05-04-2012 07:30 AM in reply to: mcgyvr
Ok...
Q1 - no
Q2 - yes
Regards
Simon
Valued Contributor
Message 7 of 7 (93 Views)
05-09-2012 08:10 AM in reply to: simon_toaldo
Thank you mcgyver and harco
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
