Inventor General
Distinguished Contributor
slphantom
Message 1 of 5 (341 Views)
view arrow instead of section lines
341 Views, 4 Replies
05-30-2012 08:44 AM
is there a way to do this? inventor 2012. for instance for a aux. view if it is not in-line with the parent view it puts a section line. is there a way to have a single view arrow?
thanks
Scott
win 7 64 bit sp1
cpu intel xeon E5-2687W0@3.106
eight core
two solid state hard drives
32 gig of ram
Autodesk product design
suite premuim 2014 64bit
Nvida quadro 4000
Space Pilot ver. 1.6.2 2010
slphantom (NNTP handle: scottl)
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 5 years
as scottl
PaulMunford
Message 2 of 5 (319 Views)
Re: view arrow instead of section lines
05-30-2012 02:07 PM in reply to: slphantom
I don't think that you can only show one arrow  - but you can right click on the line and pick 'show full line' (or something like that) to turn the line itself off.
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Employee
Message 3 of 5 (290 Views)
06-06-2012 04:46 AM in reply to: slphantom
Hi Scott,
can you please try RMB on the Aux view definition (the 'Section line') -> Edit View Annotation Style and change the Format to single arrow?
Ladislav
slphantom
Message 4 of 5 (261 Views)
06-11-2012 11:06 AM in reply to: t_pcoll
Thanks Ladislav. now on that view is there any way to have an aux. views label say View A instead of view a-a?
Scott
win 7 64 bit sp1
eight core
32 gig of ram
Nvida quadro 4000
as scottl
Employee
Message 5 of 5 (249 Views)
06-11-2012 02:15 PM in reply to: slphantom
Hi Scott,
you can Edit view label and modify it in the Format Text dialog. You'll find there "VIEW <VIEW>-<VIEW>" - simply edit it to "VIEW <VIEW>" only. If you need to re-add the <VIEW> token again: Set Type of Properties to "View Label Properties", from Properties combo-box select VIEW and insert <VIEW> token to the text. That's for editing existing views.
For the future views you want to edit Standard defaults: Manage tab->Styles Editor->Select your standard->View Preferences tab->View Label Defaults group->Select View Type (Auxiliary) and modify default View label format accordingly.
Ladislav
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
