Inventor General
Member
MarcelPigors
Message 1 of 6 (434 Views)
utx.dll & fb.dll
434 Views, 5 Replies
04-29-2013 02:12 AM
Hey guys,
got two errors with my new Inventor 2014
First one:
If I want to open the Explorer via Windows-Key + E it shows a message, that FB.dll is missing and the programm cannot be started (although the explorer opens). If I open the Explorer normally via shortcut and double click the message doesn't appear
Second one:
Same message, but it says utx.dll is missing. This message appears every time I've opened the explorer and go to a folder which contains drawing (ipt, aim, idw...). Looks as if this got something to do with the preview it makes or is trying to make.
Both files are not missing, they are actually there.
Win 7 32bit
Inv 2014 PDS Standard
Reinstall didn't help
Pls help :smileyfrustrated:
I attached the error msg (English version) as already discussed here:
http://forums.autodesk.com/t5/Autodesk-Inventor/fb-dll-system-error/td-p/3277453
*Expert Elite*
sam_m
Message 2 of 6 (432 Views)
Re: utx.dll & fb.dll
04-29-2013 02:35 AM in reply to: MarcelPigors
1 - are you sure you've installed the correct version?  32bit version for 32bit windows?  (withing sounding rude - are you sure you're on 32bit, as it's pretty rare these days?)
2 - did you install in the recommended way?  Anti Virus off, Admin account, UAC off, etc.
3 - windows up to date?  .net etc.
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
Member
MarcelPigors
Message 3 of 6 (430 Views)
04-29-2013 02:40 AM in reply to: sam_m
1. yes 100%
2. yes
3. yes
unfortunately "yes" to all three questions :-/
New Member
laura.e.lange
Message 4 of 6 (386 Views)
04-30-2013 01:30 AM in reply to: MarcelPigors
Member
MarcelPigors
Message 5 of 6 (378 Views)
04-30-2013 01:51 AM in reply to: laura.e.lange
Found a "solution" for FB.DLL
Ich downloaded Autoruns (Microsoft Homepage)
http://technet.microsoft.com/de-de/sysinternals/bb963902.aspx
Tab = Explorer
And unchecked all Autodesk entries.
Of course that's not a real solution but it stops the annoying Errormessages!
UTX.DLL Message still appears when opening a folder with Inventor files in it.
Valued Mentor
Mason-Paul
Message 6 of 6 (349 Views)
05-01-2013 06:55 AM in reply to: MarcelPigors
I've had a similar problem with the loss of windows explore, but in my case it was message saying that there was no program associated with the explorer file.
I found a helpful link http://www.winhelponline.com/blog/file-asso-fixes-for-windows-7/ this leads to a site with short programs
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
