Inventor General
Member
mlissak
Message 1 of 8 (681 Views)
unlink excel
681 Views, 7 Replies
08-04-2005 02:06 PM
i have deleted the excel file from the ipt file but when i open the part file it is still looking for the excel file. i am using inv 10 sp1 and excel 2000
Distinguished Contributor
shekarsub[Autodesk]
Message 2 of 8 (681 Views)
Re: unlink excel
08-04-2005 02:33 PM in reply to: mlissak
I'm thinking you also saved before reopening?
*Bob Van der Donck \(Autodesk\)
Message 3 of 8 (681 Views)
Re: unlink excel
08-04-2005 09:33 PM in reply to: mlissak
Did you try to break the link in the menu:
Edit > Links
This is new functionality in R10 which is intended to clean up stray OLE
links.
Bob
Member
mlissak
Message 4 of 8 (681 Views)
Re: unlink excel
08-05-2005 06:07 AM in reply to: mlissak
i am not abel to select break link
ksa3d
Message 5 of 8 (681 Views)
Re: unlink excel
08-05-2005 06:27 AM in reply to: mlissak
i have the same issue... the break link button is greyed out
Member
jhackney
Message 6 of 8 (681 Views)
Re: unlink excel
08-06-2005 08:07 PM in reply to: mlissak
By just deleting the Excel file, the parameters table still has the folder set to use the data from the Excel sheet. If you open the parameters table (the function symbol in the parts menu) you will see the yellow highlighted parameters still linked to the deleted Excel sheet. To avoid this problem, do not delete the Excel file from the browser, go to the parameters table and right click on the parameter list coming from Excel and delete the folder. This assigns all used Excel spreadsheet parameters to User variables and eliminates the linked Excel spreadsheet for good.
shekarsub[Autodesk]
Message 7 of 8 (681 Views)
Re: unlink excel
08-07-2005 10:27 AM in reply to: mlissak
Even for me it was greyed. I'm thinking there is an issue here. Need to find out more.... Thanks.
shekar
Active Contributor wei
Active Contributor
wei
Message 8 of 8 (464 Views)
Re: unlink excel
11-08-2012 03:19 PM in reply to: mlissak
Hello:
Did anybody sort out what to do with this issue?
I have the same problem. I deleted the excel file in the third party and deleted every table parameter in the Parameters Widow. (All them go to the User's Parameter Folder), But the linked excel file still in the window and the Edit/Links is grey.
Thanks!!
Wei
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
