For the first time I am really having problems with Inventors surface tools. Coincedentally I am working with imported geometry!
I am unable to thicken the end surface to match the others. The problem is that I need to save as .stl for the next person and my understanding is that Inv will only save in these formats if it is a solid.
I thought maybe a self-intersecting surface is resulting? I am in 2013. I know 2014 can do a self-intersecting sweep, so maybe it can do this as well.
I just played with it in 2014 for a little bit - I cannot make those pieces thicken either. I suspect it's the sharp corners causing the problem, but I can't find a good way around them.
I have to say - the Thicken function in Inventor lets me down almost every single time I need to use it.
Hi Barry,
if you wanna just save is as stl, you can try following work around:
0. Open attached part "thicken.ipt"
1. Move EOP below "Part_55666398.ipt" in the browser
2. Right mouse button (RMB) click to EOP>Click to "Delete all feature below EOP"
3. RMB click to "Srf41:: Derived">Click to "Copy Object"
4. Select "Composite" option in dialog and press "Ok"
5. RMB click to "Composite1" in browser> Click to "Repair Bodies"
6. Invoke "Stitch"
7. Choose "Face" Option and select all 4 surfaces in the graphic window>"Ok"
8. Click to "Finish Repair"
9. Invoke "Stitch" command and select "Srf41:: Derived" and "Quilt1" in the browser>"Apply">"Done"
10.Export>CAD Format>STL>"Save"
I hope it helps.
Martin
FYI Barry - Alias Design 2014 has no trouble thickening the surfaces to create a solid STL. Unfortunately, it will only let you do a max wall thickness of 10mm. But, I was able to scale the part to half, thicken it by 10mm, and export an STL, then import said STL and scale it 2X.
Ugh.
Anyway - I would be happy to send you the resulting STL file - it's 118MB! 🙂
Thank-you for your time and effort Micah, so 2014 is no better! I understand that Inv freeform surface options are limited. I have a feeling I'll be better off with shell instead of thicken.
I'll try the work around.
But if not I'll be bothering you for that monster, I need to find a solution.
Hi Martin
I only tried your solution today, and it's one I have not come across before.
Can you (or someone else) explain how this works, it seems to turn the solid into a surface.
