Inventor Forum
unable to create component.
9 REPLIES 9
Message 1 of 10
2157 Views, 9 Replies
Hi ,
I am having problem to insert a component from content center.
Need help.
Regards
Krishna madaiah
mkrishna@stratacontrol.com.au
9 REPLIES 9
Message 2 of 10
Inv_kaos
Have you used CC since u installed Inv? You may need to check to see if you have installed it properly or perhaps not migrated the files. Run ADMS Console to check.
Regards
Stew
Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
Message 3 of 10
i was CC till 2 weeks back. had this problem.
uninstalled ADMS, Vault, IV , content center.
reinstalled all back. this problem exists.
krishna
Message 4 of 10
Please verify:
- If you have write permission for folder where standard parts are generaed from CC. This is given by Inventor project file -> Folder Options -> Content Center Files
- When you work with standard part with thread like bolts, nut, you need path to Thread.xls describing thread, it defined by Inventor project file -> Folder Options -> Design Data
Aslo for sure look Application Option -> File. There are aslo default settings for CC part location and Design Data.
I would recommend you
- activate Default project file
- when Default.ipj is active, create new your project file, make CC location to a local folder where you have write permitions, let default Design Data as C:\Program Files\Autodesk\Inventor 2008\Design Data\
- try if you are able to place CC content supplied by Autodesk, DIN, ISO
Jan Priban (Autodesk)
Message 5 of 10
CorBergshoeff
Jan,
I have the same problem and tried al the options you've mentioned.
I have a bad feeling that it started after I had installed the 2009 beta, but I'm not sure about that. In the mean time I removed the beta but the problem persists.
regards,
Cor
Message 6 of 10
JDMather
>I had installed the 2009 beta...
Re-install r2008.
Message 7 of 10
CorBergshoeff
Is that a wild guess or a proven solution?
Cor
Message 8 of 10
JDMather
I can't say that I participated in Beta, but it is more than a wild guess on my end.
Message 9 of 10
CorBergshoeff
OK, I'll give t a try..
Message 10 of 10
I got the same error due to the Arabic standard and format setting in regional and language option in windows vista.
I changed the standard and format to English (US) and solved the problem.
Please make Hotfix for this problem.
Thank you.
