Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
twist rectanglar tube
8 REPLIES 8
Message 1 of 9
WILLIAMF
771 Views, 8 Replies
Im trying to reproduce the part attached. Its a rectanglar alumin tube. .320 x .180 approx an inch long.
I tried lofting 2 sketches but the result does appear like  the attached image.
What command should I be using?
Dell Precision 5820
Windows 10Pro
Quad Core Intel Xeon
32 Gb SDRam
NVIDIA Quadro
Product Design Suite 2019 Ultimate
8 REPLIES 8
Message 2 of 9
CCarreiras
in reply to: WILLIAMF
Hi!
You can use Loft to achieve that. You have to edit the transition rails.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 9
WILLIAMF
in reply to: CCarreiras
Yeah I thought it had something to do with the rails.
A simple loft does not achieve what I want. I will give it a try. Thanks
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
Message 4 of 9
CCarreiras
Hi!
Also in Conditions, chose Tangent for both.
Check it!
CCarreiras
Message 5 of 9
WILLIAMF
Thats it
You need to use point mapping I beleive
Correct?
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
Message 6 of 9
CCarreiras
Hi!
Deselect Automating Mapping, look at the picture.
CCarreiras
Message 7 of 9
WILLIAMF
I got the general idea, just need a little practice.
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
Message 8 of 9
CCarreiras
Hi!
Example Attached.
CCarreiras
Message 9 of 9
WILLIAMF
thanks Carlos
that is very helpful
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
