Hello.
I am new at inventor and at my first steps using the tube and pipe environnement. So I thank you in advance for your kind understanding about my neophyte question.
I have created pipe run no 1. in a top-level assembly using fittings from content center and , the necessary files were generated and all the parameters were written at the correct locations in the browser the route was set to autoroute and threaded steel pipe selected from the tube and pipe dialog box I got the expected result, excellent!
A second route was created for flexible hose using the prescribed method and standard fittings from content center, that went well also, i used the hose lenght tube to fit the hoses precisely.
Now I need to add another flexible hose run, using smaller diameter hoses ( 1/4 in. instead of 5/8 in.)
in order to do that,I clicked the tube and pipe button in the assemble ribbon and entered the file names for the new route.then I select the flexible hose no fittings from the style dialog box, then I right clicked the style to make it active and right-clicked again to edit the the hose diameter and rules, when I hit the "save" button, the changes were immediately applied to my previously completed hose route even if two distinct routes appear in the browser, also, the associative option in the right click menu for the first and second hose routes are checked but grayed out.
not what I was looking for.
can you direct me to the procedure necessary to dissacociate tube and pipe runs from each other and make them distinct. I am sure this is a basic error on my part, I have been going around in circles for some hours now and decided to risk it in the inventor forum.
again thank you for your time and patience towards a beginner's question.
have a great evening.
Charles
What version of Inventor? Any chance of posting the files here? Can you do a Pack & Go so all fittings come along for the ride? Then maybe post a zip file?
AutoCAD 2011, IV 2011 Pro SP2 Tube and Pipe - Frame Generator, Vault Pro 2011 Win 7 x64, Dell precision PWS690, GeForce GTX580
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi Chris.
Thank you for answering my question
inventor 2012 sp. 0
sorry,I have been deleting the problematic pipe runs, and started over this morning.
what I did to resolve the issue is simply creating and naming different new styles for every new run (except those using the same style of course) which seems to be the logical way to go.
again Chris your help offer is very much appreciated, I will keep following the interesting posts on the inventor forum.
Cheers
Charles
