I think my install of student version Inv 2013 pro is ok. My issue is not being able to pan as in other Autodesk programs.
Pan will work only if I press enter after holding middle (wheel) button down, moving to desired location, release button.
Is this mouse problem, a graphics problem or what? These are my specs:
Win 7 pro
Intel core i5 3.1 ghz
8 gb ram
464 gd hdd
Radeon HD6350 512mb ram
Thanks for your help.
Tom
Can you pan with other programs (adobe, autocad... anything)?
What kind of mouse are you using? Is it wireless? Mayb its too far from USB port the doggle is plugged in.
Is it programmable? Have you programmed the buttons by accident.
If you are using a wired one, try updating the driver.
If you're suggesting that middle mouse does nothing then check your mouse properties that the middle mouse button is set to "middle mouse" or "mouse 3." As an example - Logitec mice sometimes have "generic button" set to middle mouse and for some reason that used to cause problems which would be fixed by re-assigning the button to "middle mouse."
confused by the need to press enter (after clicking middle mouse) to get pan to work. almost suggests that it's a mult-button command and you need it to be launched (by enter) to work. Could make sure "Command alias input dialog" is turned off in Inventor Options -> General tab.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Hi, Tom here,
I checked my mouse button settings, middle button is set to middle button. Command alais input dialog box, unchecked.
Should I try a new mouse?
confused in GA
Tom
I'm curious how you discovered to hit Enter as that never would have occured to me.
I though maybe Inventor gave you some kind of clue that would give us a clue on how to resolve the problem.
