Inventor Forum
transfer data
2 REPLIES 2
DeerSpotter
169 Views, 2 Replies
transfer data
I have a standard assembly that changes sizes with different configurations, and every time we have to re-draw and re-baloon every part to the BOM.
Is there a better way of doing this that we don't manually have to do this each time?
like maybe replacing the assembly inside the dwg so the baloons and dims auto update? i dunno any help will be appreciated.
Thanks!
Image and video hosting by TinyPic
See My LinkedIn Profile
2 REPLIES 2
mrattray
in reply to: DeerSpotter
You could try doing a save-as of the drawing and using the "replace model reference" command to change out to the new assembly. Just be sure not to get confused between save-as and save-copy-as, you don't want to end up mucking up an existing drawing.
Mike (not Matt) Rattray
DeerSpotter
in reply to: mrattray
thank you! This is amazing, since my 2010 doesnt have it i used the "old trick" SInce my inventor version doesnt support it.
The old trick was to rename the original files, and force the drawing to ask you
for it's reference file.  You'd point it to the new copies, and you'd be off and
running (after renaming the originals again, of course).
source:
http://www.inventortales.com/2010/09/change-model-reference-making-switch.html
