Does anybody know of any program that allows you to trace a parameter or dimension throughout the entire data set, showing what files it's used in and maybe even gives a family tree of embeds?
Same for tracing ipt and iam files in the entire data set.
Anything like that out there?
Thanks ...
"Tracing" ipt & iam files is easily done through Vault.
Mike,
Thanks for that tip.
I don't use Vault, and won't.
Plus, does vault show the parameters and dimensions like I asked?
Do you know of an add-in utility that does that?
Don't know of anything out there that will trace parameters or dimensions.
Do you think this may be a good utility for more than a few people?
I need it b/c of skeletal modeling.
I found that any more than 3 levels deep causes the program to bog down real bad.
But when a model & drg gets real big, things get complicated real quick, even @ 3 levels deep max.
I need it, but wonder if others may be able to use it too?
We do a substatial amount of skeletal modeling, but for our case, I can't see where it would be of benefit to us.
We use a unique skeletal model for each project, and since we use Vault, we can track parts and assemblies.
May be of beneit to others out there though.
Its fine until someone breaks out the "Trace Buster Buster"..
Name the movie (without cheating)
