Inventor Forum
tired of placing bolts...
35 REPLIES 35
Message 1 of 36
Jayman
304 Views, 35 Replies
Does anyone know of an add-in (third party) software that has the intellegence to populate my assembly with fasteners??
35 REPLIES 35
Message 21 of 36
in reply to: Jayman
"Ok - last
reply for this one... nothing against engineers, but... they are not designers.
Really."
That's right they are not designers.  However
it does not mean they can't design.  I'm not going to get into a
verbal contest here but you are making some very bold (and incorrect)
statements.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
Watch
out Philly, Tampa's on a
roll...
Message 22 of 36
MechMan_
in reply to: Jayman
Ok Sean, slowly take your hand off the Dilber Award...it's not a weapon! 😉
MechMan
Message 23 of 36
in reply to: Jayman
Yep you got it!
Sean Dotson, PE
Check the Inventor
Watch
roll...
Message 24 of 36
in reply to: Jayman
Which command are you talking about?
Did you ever use Drew's Rivet gun tool in MDT? Insert one bolt, pick the insertion point
on it and start picking holes. Works slick.
As for iMates I really need to find the time to play and understand them more. Currently
they seem like more work than just manually constraining parts.
And yes Sean it was me that suggested adding iMates to the hole dialog. 8^)
Kent
Member of the Autodesk Discussion Forum Moderator Program
"MechMan" wrote in message news:f138d74.20@WebX.maYIadrTaRb...
> I'm not aware of any CAD package being able to do what you're saying so I guess it is a
bit much to ask. I figure a LOT of programming has to go into an intelligent command like
that.
> MechMan
Message 25 of 36
MechMan_
in reply to: Jayman
Jayman wrote:
"i think i should be able to click a thread, click the top of a plate, answer yes/no to a washer and BANG!!! Done! Is that so much to ask for in a mech design package?"
That's the theoretical command I was referring to.
No I've never tried the rivit gun tool. Sounds great. I used MDT since Designer R1 but was never privy to these great user groups so that I could learn from others. B-(
Oh well, better late than never.
MechMan
Message 26 of 36
in reply to: Jayman
You ever worked for a designer, Sean? ...
And here I've spent all this time do'n it the other way around: working for
engineers ... Sheech ... I need to get out more. <G>
~Larry
You are looking at one buddy!
But let's not get into a engineers vs. designers
debate...
Sean Dotson, PE
Check the Inventor
Watch
roll...
Thats precisely the problem - it was designed by "engineers" NOT
designers. I would like to sit one of these "engineers" down and watch them
build a machine from start to finish. At the same time dealing with customer
changes and physical machine restrictions. IV6 is a bit better but... example
- exporting the entire bom from the top level assembly.
Message 27 of 36
in reply to: Jayman
I don't think I know any engineers that can't
design. What do they do if they don't design stuff? ... We're not just
talking cosmetic design, are we? I know some engineers that don't care
much for that part of it.
~Larry
"Ok - last
designers. Really."
However it does not mean they can't design.  I'm not going to get
into a verbal contest here but you are making some very bold (and
incorrect) statements.
Sean Dotson, PE
Check the Inventor
Watch
roll...
Message 28 of 36
in reply to: Jayman
Not sure what your point is. Half of my career has been trying to make
something workable out of the %$#*&^% the 'designers' have inflicted.
Oh! Maybe I do get it! If IV had been programmed by Designers it would
be truly unworkable.
Richard
> them build a machine from start to finish. At the same time dealing with
> customer changes and physical machine restrictions. IV6 is a bit better
> but... example - exporting the entire bom from the top level assembly.
> Nuff said - i am getting all flush!!
Message 29 of 36
in reply to: Jayman
Design Engineers right!..........That's
Draughtsmen, they were Designers when they were drawing and Draughtsmen when it
went wrong. The boss says he's chief Design Engineer so there and your the
lad...............and then he say's I am only a Process Engineer when the
pressure's on, I nether wanted the job anyway?!
Can't win can you.
Laurence,
Power is nothing without
Control
just talking cosmetic design, are we? I know some engineers
that don't care much for that part of it.
~Larry
"Ok - last
designers. Really."
Sean Dotson,
PE
Message 30 of 36
in reply to: Jayman
Just to pour a bit of oil into the
fire...
It would be VERY helpful for Adesk to understand
the needs of their customers if they would run a engineering/drafting service
business in every major country out there and poll the user complaints
regularily... And they for sure should push the boss in every of those offices
to earn good money with this business, and this local boss will tell Big Adesk
Boss then how he could make even more money if he had a more efficient
tool...
This is how poor little Leo from the mountains
believes how things could grow better...
Leo Laimer
Maschinen- und
Fertigungstechnik
A-4820 Bad Ischl - Austria
Message 31 of 36
in reply to: Jayman
For once I agree with you Leo, well I do most of
the time, wouldn't that be great if the boss's actually were interested in
engineering in general (electrical and mechanical) I do believe that no where
else has the decline in mechanical manufacture taken a country ( GB
) down to near extinction.  Even if you ere on the side of pessimism,
the good thing is that there are enough optimists here to drag you kicking and
screaming back into the light 🙂
Is there a spare bunk and desk in your cabin <g> Can't ski
though.
Laurence,
Control
fire...
tool...
Leo Laimer
Maschinen- und
Fertigungstechnik
A-4820 Bad Ischl -
Austria
Message 32 of 36
in reply to: Jayman
Come on, Laurence, I have a spare seat of IV, and
lots of work...
Would like to learn your British language
anyway.
Leo Laimer
Maschinen- und
Fertigungstechnik
Message 33 of 36
in reply to: Jayman
How about a Texan language?
<G>
~Larry
lots of work...
anyway.
Leo Laimer
Maschinen- und
Fertigungstechnik
A-4820 Bad Ischl -
Austria
Message 34 of 36
in reply to: Jayman
Better ask if you can take the cats. 8~)
"Larry Caldwell" wrote in message
news:D67BA611440AF403A97DB8A9025A00AF@in.WebX.maYIadrTaRb...
~Larry
"Leo Laimer" wrote in message
news:C2E4CD3932E44ED155347672EF11AB66@in.WebX.maYIadrTaRb...
Come on, Laurence, I have a spare seat of IV, and lots of work...
Would like to learn your British language anyway.
Message 35 of 36
in reply to: Jayman
Seven airline tickets! ... Sheech! ... But look at all the luggage I could
carry.
~Larry
"Jeff Howard" wrote in message
news:4B64388273C15F1FDC9DC11E3D788D34@in.WebX.maYIadrTaRb...
Message 36 of 36
in reply to: Jayman
I just stumbled over a neat trick while inserting a bunch of fasteners:
1/ Copy a fastener
2/ Paste the fastener
3/ Open the constraint dialog box and constrain the fastener
4/ While the constraint dialog box is open, paste another occurrence of
the fastener.
Not huge but it saves a click or two when placing fasteners in tricky
places that require view changes.
Richard
