Inventor General
Active Contributor
Message 1 of 6 (319 Views)
time stamp MIA
319 Views, 5 Replies
07-26-2011 08:18 AM
How do you get a simple time stamp on a .idw??
I've  have a time stamp field but it won't show up.  I've been in the template to edit; iprops, field edit; border edit........  No luck.
Any thoughts?
*Expert Elite*
Curtis_Waguespack
Message 2 of 6 (313 Views)
Re: time stamp MIA
07-26-2011 08:34 AM in reply to: PENengr
Hi PENengr,
Here is one solution from the guys at the BeingInventive blog:
http://beinginventive.typepad.com/being-inventive/2011/07/plot-date-stamp-in-title-block.html
It might be helpful to attach an example file for others to look at as well.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Contributor
Message 3 of 6 (298 Views)
Re: time stamp MIA
07-26-2011 09:21 AM in reply to: Curtis_Waguespack
Curtis, this is great! however--- I made this rule in our .idw template but when other draftsman printed it didn't carry over.  Am I missing a setting or something?
*Expert Elite*
Curtis_Waguespack
Message 4 of 6 (283 Views)
Re: time stamp MIA
07-26-2011 10:08 AM in reply to: PENengr
Hi PENengr,
It's difficult to tell without seeing the rule and/or a sample file.
Can you attach an example file for others to look at ?
I hope this helps.
Curtis
Active Contributor
Message 5 of 6 (280 Views)
Re: time stamp MIA
07-26-2011 10:13 AM in reply to: Curtis_Waguespack
Yes.... attached.  I'm reading your blog http://inventortrenches.blogspot.com/2011/02/ilogic-code-for-parts-lists-title.html
and trying to make my ilogic rule an external rule????  .......Greg
*Expert Elite*
Curtis_Waguespack
Message 6 of 6 (249 Views)
Re: time stamp MIA
07-26-2011 06:24 PM in reply to: PENengr
Hi PENengr,
Nice job on the title block.
It looks like your custom iProp in your border got lost. I won't venture much of a guess as to why, other than to say that if you're anything like me you got pulled away in the middle of this and forgot to save or something along those lines.
Also, I couldn't tell for sure if you were asking about how to create an external ilogic rule (as opposed to an embedded rule), but if so here goes: Just set the External Rules tab active on the iLogic Browser and then right-click on the top level node and select Create New External Rule
you can change the external rule search paths as shown here:
http://inventortrenches.blogspot.com/2011/03/change-path-for-dlls-and-net-assemblies.html
I hope this helps.
Curtis
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
