I am creatng columns and beams for a power plant and a few of my assemblies that I have drawn in thus have a reverse - is there an easy way to reverse the assembly?
Thank you for your help 🙂
Angela
Solved by tsreagan. Go to Solution.
Solved by blair. Go to Solution.
1.) Either use the "Back" for your base view rather than the "Front".
2.) You could unground the base component in the IAM and change the orientation which will flip the model.
3.) In the IAM, view the view cube and RMB on the View cube and set your Front there with the "Set Current View>Front.
