Inventor Forum
text on curve in drawing IV2010 - how to hide curve?
8 REPLIES 8
Message 1 of 9
edras
754 Views, 8 Replies
I have used the Geometry Text command in the sketch mode to apply text that follows an arc I have sketched. That part works very well. However, the arc is intended only for a construction line. How do I hide it? I can change the color, but don't seem to be able to make it invisible. Thanks for your help.
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: edras
Are you in drawing (idw) or in part (ipt)? In drawing can you set the properties of the arc to Sketch Only?
Message 3 of 9
JDMather
in reply to: edras
See Attached.
Message 4 of 9
mcgyvr
in reply to: edras
Don't think you can make it invisible.. But you can change it to the same color as your drawing sheet.
Message 5 of 9
JDMather
in reply to: edras
Sure you can. I just did it to verify.
Message 6 of 9
edras
in reply to: edras
JD,
I am in the drawing mode. When I select the arc and go to properties, I do not see any choice for sketch only.
Ed R
Message 7 of 9
mcgyvr
in reply to: edras
there ya go.. Good one JD. Never seen that button before.
Message 8 of 9
JDMather
in reply to: edras
>When I select the arc...
Do what I mean, not what I said. ;~)
Message 9 of 9
edras
in reply to: edras
JD,
When I saw the menu view you attached, that showed me what to do. You are correct. The sketch only icon choice for the arc does just what I needed. Thank you very much for your help.
Ed R
