Inventor General
Active Contributor
paul_pearson
Message 1 of 4 (145 Views)
Accepted Solution
text alignment
145 Views, 3 Replies
07-16-2013 04:02 AM
Hi
I have text in a circular shape but how do i place the text inside the part on to the front of the face?
Paul
Inventor 2013
*Expert Elite*
JDMather
Message 2 of 4 (139 Views)
Re: text alignment
07-16-2013 04:14 AM in reply to: paul_pearson
You could have used the inside arc rather than the outside arc.
In either case, enter the Offset Distance.  (edit the sketch and double click on text)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
-niels-
Message 3 of 4 (134 Views)
Re: text alignment
07-16-2013 04:18 AM in reply to: paul_pearson
you could delete the constrain from the outer circle, making it normal geometry instead of projected, and then dimension the circle so it's on the inside.
Using IV2014 Pro SP2, Win7-64bit
Active Contributor
paul_pearson
Message 4 of 4 (95 Views)
Re: text alignment
07-16-2013 09:03 PM in reply to: -niels-
Thank you
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
