Inventor General
Active Contributor
Message 1 of 4 (132 Views)
text alignment
132 Views, 3 Replies
07-16-2013 04:02 AM
Hi
I have text in a circular shape but how do i place the text inside the part on to the front of the face?
Paul
Inventor 2013
Message 2 of 4 (126 Views)
Re: text alignment
07-16-2013 04:14 AM in reply to: paul_pearson
You could have used the inside arc rather than the outside arc.
In either case, enter the Offset Distance.  (edit the sketch and double click on text)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
-niels-
Message 3 of 4 (121 Views)
Re: text alignment
07-16-2013 04:18 AM in reply to: paul_pearson
you could delete the constrain from the outer circle, making it normal geometry instead of projected, and then dimension the circle so it's on the inside.
Using IV2014 Pro SP1 update 1, Win7-64bit
Active Contributor
Message 4 of 4 (82 Views)
Re: text alignment
07-16-2013 09:03 PM in reply to: -niels-
Thank you
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
