Inventor Forum
sweep won`t work
5 REPLIES 5
607 Views, 5 Replies
sweep won`t work
What do i change or why does the sweep not work on this sketch
5 REPLIES 5
Good morning,
everthing works fine with Inv2014.
Peter
WHolzwarth
Sometimes creating another 3DSketch by Include Geometry does help. See file.
Walter
Walter Holzwarth
johnsonshiue
Hi! The issue is that there is a degenerated line segment (point) in the middle where the two bends are. Sweep does not seem to like the condition. If you replace the two bends with a half circle, it should work better.
Thanks!
Software Test Engineer
in reply to: johnsonshiue
this was also my first suspicion. But bend on bend  works fine without a straight pipe segment between (with Inventor 2014).
Peter
1.You have to change radius 110 to a smaller value like 100 or so.
2.sweeping with 3D-Sketch
3.after sweeping Change radius back to 110mm
