Inventor General
Distinguished Contributor
JDMATHER
Message 21 of 22 (31 Views)
Re: surface stitch part and mass properties
11-12-2004 01:00 PM in reply to: Lisztman
>so do you suggest i try another format to export out of rhino?
stp
sat
I saved the file as an IGES in Inventor and then opened the IGES in MDT. The surface normals for the two fillets were backwards. Of course it had been washed through Inventor so that might be misleading. It might have been interesting to analyze the original Rhino and then the Rhino IGES file in MDT. It is interesting that the more complex fillets were OK but these two around an elongated slots were not. Seems like I see that a lot and not just from Rhino? It might have been best to leave these simple fillets out when modeling in Rhino.
Anyway a step file is probably your best bet.
Active Contributor
Lisztman
Message 22 of 22 (31 Views)
11-12-2004 01:34 PM in reply to: Lisztman
okay, i got it all worked out. i took the SAT file from orchdes, opened it in inventor. i then saved it as another SAT file with "configuration controlled design" and imported it into MDT. it opened up as a solid, and it seems to work perfectly now.
thanks very much everyone. ill have to look into Transmagic.
Trevor
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
