I am trying to make a way that suppress the flange features of all the panels that will be insert in the assy so i can suppress al the features at ones in a assy and don't have to do that for each panel separately.
I have a assy with parameters and i have a part with no geometry but have linked the parameters from the assy.
In my panel part i link the parameters to the part with no geometry.
When i use the parameter in the assy to suppress the flanges that works the way i want it.
But when i insert the panel part into that assy it dus't work.
I think i miss a link, can anybody help me out?
I am now ready to succeed to suppress the flanges off the parts in my assy.
The problem now is that if I place a panel with 'Place' it goes well even if I use a different type of panel.
But if I place the panel on "Place iLogic Component" then it does not work.
The panel is the same as when I was with 'Place' insert.
Everything is linked to the same parameters and the same part, the part 'Koppeling'.
Can somebody help me out.
