I created 2 solids (each in different plan) and then i intersected them. How can i subtract one of them like in AutoCAD?
When i extruded one of them, the option "hole" was disabled so i can't make a hole. Does exists into inventor a function like subtract in autocad?
Solved by Curtis_Waguespack. Go to Solution.
Hi nicu_bogd,
You can use the Combine tool, to subtract Solid1 from Solid2.
I hope this helps.
Curtis
While you can use Combine (subtract option) there is most likely a better way.
Attach your file here, I don't understand this "the option "hole" was disabled".
I solved the problem with Combine. Thanks. I don't know why when i extruded it, the button "hole" was disabled.
Attach your file here and someone will show you a better way.
I've never even seen this button "hole" in the way you describe.
At least post a screen shot.
