Inventor General
jrittenhouse
Message 1 of 5 (284 Views)
step file import
284 Views, 4 Replies
11-06-2012 02:31 PM
Im importing .stp files and only want to imort the surfaces, but some files have to have the solid imported as well.  Can anyone tell me why the file is like this?
JDMather
Message 2 of 5 (283 Views)
Re: step file import
11-06-2012 02:34 PM in reply to: jrittenhouse
What Options did you set for import?
Can you zip and attach the original STEP file here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
jrittenhouse
Message 3 of 5 (279 Views)
11-06-2012 03:03 PM in reply to: jrittenhouse
wrong terms.  Im opening the file and changing the options, then saving as all file and placing into assembly file.  I jsut need to know why the file has to have the solids brought in and not the surfaces.  Is it how its saved or created?
JDMather
Message 4 of 5 (267 Views)
11-06-2012 03:37 PM in reply to: jrittenhouse
Can you attach the file here?
Yes/No
Employee
KevinLi-Autodesk
Message 5 of 5 (259 Views)
11-06-2012 06:03 PM in reply to: jrittenhouse
Hi jrittenhouse,
Thanks for your report and I suppose you use Inventor professional 2013.
If your STEP file has the solid and surface definitions, then when you place it into assembly via Assembly tab -> Place button -> select your STEP file -> hit Options -> only turn on "Surfaces" checkbox in "Entity Types to Import" group, turn off all other options, only surface geometry should be imported. If that is not the case, it is a defect then.
In order to narrow down and reproduce your problem and investigate it, it is better to has your STEP file just as JD's suggestion. You can attach it in this forum or send it to me Hongyuan.Li@autodesk.com , if the model is very large I can create a safe FTP server for you to post.
Thanks for your support !!!
Kevin Li
Quality Assurance Team
Kevin-Hongyuan Li
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
