Inventor Forum
spur gear
0 REPLIES 0
Message 1 of 1
257 Views, 0 Replies
spur gear
Hi
I need a spur gear set. All my attempts have led to an error of some sort, usually a bad internal/small gear.  The specs for the set go as follows:
- large gear with inside teeth with max outside diameter of 14.5"
- a spur gear that will go inside the large gear with a .5" bore (preferably 9 teeth)
- 10 to 1 gear ratio.
- teeth on both gears should be .187" minimum height
Tags (1)
0 REPLIES 0
