Inventor General
Message 1 of 1 (122 Views)
spur gear
122 Views, 0 Replies
02-23-2012 07:11 PM
Hi
I need a spur gear set. All my attempts have led to an error of some sort, usually a bad internal/small gear.  The specs for the set go as follows:
- large gear with inside teeth with max outside diameter of 14.5"
- a spur gear that will go inside the large gear with a .5" bore (preferably 9 teeth)
- 10 to 1 gear ratio.
- teeth on both gears should be .187" minimum height
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
