Inventor General
Active Contributor
Message 1 of 10 (773 Views)
sprockets
773 Views, 9 Replies
01-15-2013 08:05 AM
Does anyone have a good place to get 3d models of roller chain sprockets? I've been looking for a while now but i can't find anything that provides the variety or accuracy i need.
Mason-Paul
Message 2 of 10 (765 Views)
Re: sprockets
01-15-2013 08:21 AM in reply to: danielw88
You might like to try here http://grabcad.com
Inventor 2013 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Mhz CPU , 32 GB Ram
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Active Contributor
Message 3 of 10 (758 Views)
Re: sprockets
01-15-2013 08:35 AM in reply to: Mason-Paul
They had alot, but not what i needed.
Distinguished Contributor
Message 4 of 10 (753 Views)
Re: sprockets
01-15-2013 08:40 AM in reply to: danielw88
Message 5 of 10 (740 Views)
Re: sprockets
01-15-2013 09:06 AM in reply to: danielw88
Are you aware that there is a sprocket generator built into Inventor?
I have an Excel driven sprocket based on Machinery's Handbook specs that you might be interested in if the Design Accelerator sprockets won't work for you.  You might have to edit it to meet your needs.
Give me sample specs for one that you need.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Contributor
Message 6 of 10 (735 Views)
Re: sprockets
01-15-2013 09:10 AM in reply to: JDMather
I haven't used the sprocket/chain feature in Inventor for a while. The last time i used it, if i can recall correctly, generated a pair of discs (with not teeth) with a blue, transparent chain mock-up.
The sprockets i need are H80B48, H80B15, H60B60
Message 7 of 10 (732 Views)
Re: sprockets
01-15-2013 09:12 AM in reply to: danielw88
My memory isn't that great - but I don't recall a release that didn't generate real teeth.
I have never bothered to check the DA generated toothform against my Machinery's Handbook spec generated toothform as sprockets are generally purchased off the shelf and my purpose for doing the geometry myself was simply to use something interesting to demonstrate how to create an iPart.
The chain is generated as a simplified blue, tranlucent representation.
Active Contributor
Message 8 of 10 (728 Views)
Re: sprockets
01-15-2013 09:17 AM in reply to: JDMather
Then your memory is better than mine because i just checked and the generator does include teeth on the sprocket discs.
Thanks for your help, other than not having a hub, those sprockets will serve their purpose. I can't belive i had forgotten about that feature.
Message 9 of 10 (721 Views)
Re: sprockets
01-15-2013 09:23 AM in reply to: danielw88
Simply edit the part to add hub and hole as needed.
Valued Mentor
BLHDrafting
Message 10 of 10 (693 Views)
Re: sprockets
01-15-2013 06:00 PM in reply to: danielw88
I give a thumbs up to Traceparts.Has all the sprockets I could ever need.
http://www.tracepartsonline.net
 Do a search or look in here :-
Mechanical systems and components of general use > Flexible drives and transmissions > Chain drives and their components >
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
