How can i get this spring to have more revolutions.I am looking for a more compressed looking spring
Regards
Simon
Hi!
The problem is, the coil its self-intersecting in the start and end.
Edit the Coil and play with the "Transition Angle" and "Flat Angle" values in the "Coil Ends" Tab.
For instance, if you reduce the "Flat Angle" to 130 Deg, you can have one more Revolution.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
