Anybody know where i can find models for coiled style spring pins. I can find roll pins but not coiled.
thanks
msk
Solved by Curtis_Waguespack. Go to Solution.
Solved by sysh. Go to Solution.
I attached a part file here. Is this exactly what you wanted? If yes, then you can find them from Content Center.
Thanks.
STUPID ME, I forgot to post my version. Thanks for the help but I guess you're on 2011 and we decided to skip and wait for 2012 to load upgrade. I'll go back and double check content center, I looked there and could not see the rolled coil style I was looking for.
MSK
Do you use Inv 2010? I attach another two parts based on 2010. But I 'm not sure if they are exactly what you wanted. I find them from content center (Fasteners / Pins / Cylindrical (Pin-Coiled Spring and Pin-Slotted Spring).
Hope that Helps.
Thanks.
Yes, we use IV2010 and when I looked in Content Center I missed them. When I went back and looked yesterday I did find coiled roll pins in there, don't know how I missed them the first time. Just blind I guess.
MSK
might be a silly question but i am looking in the content center because i want to add them to my companies custom content center and cannot find them.
Hi Fori123,
In the Place From Content Center dialog box, or the Open From Content Center dialog box, there is a search button (looks like a magnifying glass). You can use this to search for "Spring Pin" and/or "Coiled Pin"
Or look in Fasteners > Pins > Cylindrical
You might need to click the filter button (looks like a funnel) and deselect any filters you have applied.
I hope this helps.
Curtis
Thank you so much. I was able to find them, now comes the task of learning how to add them to my companies custom defined content center.
in CC right click on the part in question... select copy to, and select the CC DB you want a copy of it in. Done.
Hi Fori123,
Here is a good place to start:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-ECDD0F38-2706-4165-937D-D4E2A8750C4C
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-2BD50DB4-09E9-4B89-9BC7-48FD514AC1B5
I hope this helps.
Curtis
