Inventor General
New Member
thatnewguy
Message 1 of 2 (372 Views)
splitting curved faces into two faces
372 Views, 1 Replies
01-11-2013 08:13 PM
i got Inventor recently, and i've been working on a model of a longboard just to teach myself how to use the tools in Inventor. right now i'm trying to color areas for the griptape pattern so i drew the 2D pattern and projected it onto the 3D model of the longboard. but when i tried to split the faces of the model along the projected pattern only a few of the projected lines split the faces. for other faces i kept getting these errors:
Create parting line failed
Crane.ipt: Errors occurred during update
Split11: Could not build this Split
The attempted operation did not produce a meaningful result. Try with different inputs.
i have no idea what to do to fix this. help?
JDMather
Message 2 of 2 (338 Views)
Re: splitting curved faces into two faces
01-12-2013 10:11 AM in reply to: thatnewguy
You do not have to create a 3D sketch - you can split a part face directly with a 2D sketch.
My recommendations:
You are doing wayyyyyyyy too much work.
Go  through the built in Help>Learning Tools>Tutorials and Skillbuilders
Go through http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Go through http://inventortrenches.blogspot.com/p/inventor-tutorials.html
Go through the rest of the tutorials in my signature and THEN come back to this project that you are working on.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
