My customer sent me .iges files first. When I try to open them, all I get is surfaces (need this to be solids). They then sent me .sldprt files. When I try to open them, the translation report comes up and it has "Error" in it. Parts will not open in Inventor. Thinking it might be a version issue between his solidworks and Inventor 2011.
Could someone open this up and save it to a file that I can open in 2011?
Solved by JDMather. Go to Solution.
STEP would have been a better option.
Hi karthur,
I converted both parts into step format, import into Inventor 2013 was possible without any problems. I saw you are currently on Inventor 2011 so I did not attach the ipt's here. Please find the zipped step files attached.
HTH
Matthias
Just saw that JD was faster
