Inventor Forum
simple question
3 REPLIES 3
Nitro58
110 Views, 3 Replies
simple question
I created an assembly, a lot of parameters of parts are linked to an excel sheet (embed).
My question is : my assembly have a few sub-assemblies, and every sub-assembly has a drawing. How can I automatically update those drawings without having to open every sub-assembly to update it manually?
thanks
** I posted it last week, had no answer so posting again
3 REPLIES 3
Nitro58
in reply to: Nitro58
ok, for now here are my ideas.. but I don't know which one is the best :
1 - create one main assy that contains all the sub-assys, I would have to Update only ONE assy before opening my drawings.
2 - I tried the "Task scheduler" , no succes, the sequential tasks were not working. (Update Assy, then Update Drawing), when I opened the drawing I still had a message it was not Updated.
3 - Maybe something is possible with Vault ?
4 - A Macro or VB, routine, something like ( Open assy, Update assy, Open drawing), for each sub-assy. But I don't know how to use Macros yet.
Well, your suggestions?
Thx again
henrikubbe4438
Hi Nitro58
What kind of update are you trying to do?
A Tools-Rebuild all should update all the subassemblies as well as the top one.
IV11, that is.
/Ub
Nitro58
I don't need a global update, juste an update. I don't see the Rebuild option in an idw.
Since I posted, I tried a few things and it is currently working ok, my macro is pretty simple, but I don't know anyone to help me, so I do my best.
Public Sub Open_update_save_close_open()
ThisApplication.Documents.Open ("T:\Inventor project\Projet_name\Project_assy.iam")
ThisApplication.ActiveDocument.Update
ThisApplication.ActiveDocument.Save
ThisApplication.ActiveDocument.Close
' Open the drawings needed
ThisApplication.Documents.Open ("T:\Inventor project\Project_name\DRAWINGS\Project_assy.idw")
' Remove all unattached dimensions
' Set a reference to the active drawing document
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oDrawingDim As DrawingDimension
' Iterate over all dimensions in the drawing
' and delete unattached (sick) dimensions.
For Each oDrawingDim In oSheet.DrawingDimensions
If oDrawingDim.Attached = False Then
Call oDrawingDim.Delete
Next
End Sub
Then I repeat some commands to open a few more idw. The whole thing takes about 12 seconds, which is ok for me. Now, I want to save a copy of those drawings in another folder, because those base drawings can't be edited. I tried pack and go, but the link with the excel sheet was still there. Any suggestions?
(Inventor 2008 series. HP workstation xw4400, 3 GB RAM)
