i need to build about 8 versions of this simple box (see pic). base size, top size height... easy!
i have been using simple extruded boxes for most of my work to create the "path" of the frame, but with the tops being smaller than the base i need a new trick. also i know i will make more and more versions and would like to make new sizes a quick and simple job.
thanks!
ian
ok, but im wanting to use the F.G. more as our shop uses steel tube & pipe about 99% of the time.
im messing around with this task and have now got a new question. how do i add to the exising ANSI tubes? i made a copy of the ANSI square shapes and then made a copy of the 2x2 3/13. i then edeted the 2x2 to be 1x1 and the wall to be .120. revised the corner rad and all looks good untill i use the tube... its showing up as 1x2....
ok... so you all wanted to do it some other way. i get it.
does anyone have anaswer as to how to di it with the frame generator and quickly make changes?
height of box
size of base
size of top
thanks
-ian
