Inventor General
admin
Message 1 of 3 (151 Views)
showing section view in base viw
151 Views, 2 Replies
12-13-2012 02:14 AM
Dear sir,
plz suggest me the procedure how to show section view in base view with out projection the component.
regards
RS MODI
Valued Contributor
nannerdw
Message 2 of 3 (139 Views)
Re: showing section view in base viw
12-13-2012 04:05 AM in reply to: admin
Select the view on your drawing, and click "Create Sketch" from the "Place Views" tab.  (Make sure your view is selected before you create the sketch, so the sketch will be contained within the view).
Now draw a rectangle around the outisde of the whole part.  Anything within the closed area will be sectioned.
Click "Finish Sketch."
Click "Break Out" on the "Place Views" tab, and select your view.
For the depth, I'd probably select "From Point, 0.000," and pick a point on the outer edge of one of the cylindrical features, since that point will be located at the right depth for the section to go to the exact center of the part.
-Using Autodesk Inventor Professional 2012
Product Support
jingy
Message 3 of 3 (102 Views)
12-17-2012 12:00 AM in reply to: nannerdw
There is another process to get what you want.
1, create base view, and move it out of the drawing area
2, create section view from base view
Then only the section view is in the drawing area and printable.
Yong Jing
Product Support Specialist
Frontline Technical Support, CSS. GCSO
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
