Inventor General
Valued Contributor
Mike686
Message 1 of 4 (309 Views)
show appearances in part list
309 Views, 3 Replies
01-18-2013 01:17 PM
Hi, i'm trying to show the appearance of the part in a part list next to the column material
and i can't find how to do it
can someone help me?
Product Design Suite 2013
Cadmanto
Message 2 of 4 (272 Views)
Re: show appearances in part list
01-21-2013 05:04 AM in reply to: Mike686
See if this link helps you.
http://forums.autodesk.com/t5/Autodesk-Inventor/Export-BOM-parts-list-with-thumbnail-image/td-p/2662...
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Product Support
Message 3 of 4 (267 Views)
Re : show appearances in part list
01-21-2013 05:19 AM in reply to: Mike686
Here is a possible solution using an “illogic” rule you could use in a BOM of an idw file to show the "value" of the "appearance" of the model.
But several things need to be done to make this work:
Step 1:
Add the following iLogic rule on every existing parts file (or directly into the template if necessary).
It will create a custom property called "Appearance" and will copy the value of the "Appearance" of the ipt file.
Trigger the rule "Before Save Document". This is important to make sure that the color in the custom property stays up-to-date every time the part gets saved:
customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
     prop = customPropertySet.Item("Appearance")
Catch
     customPropertySet.Add("", "Appearance")
End Try
iProperties.Value("Custom", "Appearance") =  iProperties.PartColor
Step 2:
Go in the assembly (iam) and edit BOM>Add iProperties column> create a new column >write Appearance>ok
To verify Edit “BOM” and verify the column “Appearance” is visible > Save the template.
Step3 :
Start a new drawing. Go to the “Document Settings”  > “Drawing tab” > "Additional Custom Model iProperty source" to select the ipt file prepared in Step 1 > “Copy Model iProperties Settings” to select the “Appearance”.
Place a view of the Assembly prepared in step 2 and insert a BOM
Edit BOM  > Column Chooser > New Properties > select “Appearance” > ok
=> A new column should be visible with the Appearance value of the different components..
Remark: You could have also the possibility to include all these manipulations directly in your templates.
I hope this will help you.
Please, mark any response clicking on "Accept as Solution" button if it answers your question
Nicolas Bourquin
Valued Contributor
Mike686
Message 4 of 4 (207 Views)
01-22-2013 11:10 AM in reply to: Nicolas.Bourquin
thanks nicolas
i will try your method
and i will give you news if this works for me
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
