Inventor Forum
shorten after notch
2 REPLIES 2
558 Views, 2 Replies
shorten after notch
As i discovered, frame generator is a very handy tool to make a frame, and to connect beams to each other.
For a customer we need to build a large frame, The outer beams are connected directly to each other. The beams inside the outer frame need to have a gap because of mounting and welding.
What i am looking for is a kind of tool, where i can add a notch, and after the notch, shorten the beam with 1 mm at each side to make a gap, which is needed for welding.
Inventor gives an error if i add first a notch followed by a Lengthen/Shorten command.
Can somebody please help me with a solution to add a notch and a gap of 1 mm to a connecting beam?
Thanks in advance,
Paul van Deursen
2 REPLIES 2
Cadmanto
Paul,
The notch should be nothing more then a simple extruded cut.
As far as the gap on the ends of the extruded members, why not adjust the length of the line segment in your skeleton part to show the shortened gap.  This way it will automatically give you the desired gap you need.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
JDMather
in reply to: Cadmanto
I read this as the OP wants to have a gap after Notch feature.
Many (most?) of the Frame Generator editing tools include option for adding a Gap.
The offset gap could be added several ways after a Notch feature, but not with the Frame Generator editing tools.
(Extrude-cut, Split, Sculpt, Copy Object, Thicken/Offset, Thicken-cut, Move Face come to mind.)
