Inventor Forum
shell
10 REPLIES 10
Message 1 of 11
tborland
792 Views, 10 Replies
shell
Please see Shell 2 .. it shells out but how do i have the Shell to the curved face on Revolution 1.I want the Shell to cut through Extrusion 1 and to the Revolution 1 curved face
Regards
Tony
10 REPLIES 10
Message 2 of 11
JDMather
in reply to: tborland
Shell works on entire solid body.
You have two solid bodies.
You will have to Extrude Cut between the two.  (you might Combine first, depending on design intent)
Message 3 of 11
tborland
I combined both solids and then made the cut.The cut out created is what i required but now i cannot get the fillet to work....Any thoughts on how to get the fillet-4 on the end to remove not add
Regards
Tony
Message 4 of 11
JDMather
Your logic doesn't make sense to me.
I think those fillets should be added before combine and I don't understand why you couldn't use shell?
Slice that feature in half and look at the wall thickness.
Shouldn't there be a fillet on inside as well?
Message 5 of 11
tborland
That is why i asked for help.Why do you not post how you would accomplish this then
Yes you are correct  there should be a fillet on the inside....just did not get to that point yet as i was not sure if the correct flow path is being used
Thanks anyway
Tony
Message 6 of 11
tborland
in reply to: JDMather
JD,Unless i have misunderstood you ,you mentioned extrude cut in your first post
Message 7 of 11
JDMather
Tony
As I stated - I don't understand your design intent, but maybe this is something close to what you are after (see attached)?
Is Extrude Cut 4 in my example what you are after?
Hmm, tried to attach 3 times and don't see the attachment.
Finally worked with Chrome but not with IE.
Message 8 of 11
tborland
That is what i want except i do not want it to cut into Revolution 1 wall
Message 9 of 11
JDMather
Then delete it, or maybe you want to Offset Surface 2mm or something and Extrude To the surface?
Message 10 of 11
tborland
Thanks JD
Thats what i was after.Appreciated
Now i use the Circular pattern and it errors when i select the delete face...if i do not use the delete face in circular pattern it works
Message 11 of 11
tborland
The circular pattern i got work
Thanks for your help
Tony
