Inventor General
Distinguished Contributor ijc
ijc
Message 1 of 4 (191 Views)
shell
191 Views, 3 Replies
10-03-2012 05:04 AM
I`m trying to shell out the Neck on this volute but it does not work with the Shell feature.What can i do to get the Neck (sweep 1 ) to be Shelled out?
The version attached is 2013
IJC
Valued Mentor
Valued Mentor
wh
Message 2 of 4 (182 Views)
Betreff: shell
10-03-2012 05:28 AM in reply to: ijc
Perhaps this way ..
Walter
JDMather
Message 3 of 4 (181 Views)
Re: shell
10-03-2012 05:30 AM in reply to: ijc
The Shell commands works on an entire solid body - not just a feature.
Either - create that geometry first in your history tree and shell before creating the rest of the geometry
or
create that geometry as multi-body solids so that it can be shelled (you can then Combine if desired, but it looks to me like that should be multi-body anyhow).
Hmmmp, looks like Walter modeled the solution while I was typing.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
ijc
Message 4 of 4 (171 Views)
Re: shell
10-03-2012 05:38 AM in reply to: JDMather
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
