"dhoerig" <how
href="mailto:dhoerig@shafervalve.com">dhoerig@shafervalve.com> wrote in
message
href="news:f125015.-1@WebX.maYIadrTaRb">news:f125015.-1@WebX.maYIadrTaRb...
do you get the sheet name into the title block, other that using a prompted
entry?
@chrisw01a wrote:
@dhoerig wrote:
how do you get the sheet name into the title block, other that using a prompted entry?Is there any method available now to accomplish this? I would like to do the same thing...
@chrisw01a Is using "ilogic" an acceptable solution..
Its easy to get the active sheet name.. But how exactly do you want it to work..
Do you have multiple sheets?
Here is a sample of how to get the active sheet name and display it.. You could write that to a custom iproperty for the sheet and then use that to populate the title block..
SName = ActiveSheet.Name MessageBox.Show(SName, "Drawing Sheet Name Is")
Cool.
For example, I have 2 sheets. In the browser I rename them to "part1", and "part2, part3"
I just want that info to display in a text box on my sheet.
So if I change it in the browser, it should update on the sheet.
Thank you.
Can iLogic access a "text box" by ID or name?
I could have a standard text label and have iLogic populate it with the sheet name, but I don't see a way to get to the text box from iLogic.
It could also work the opposite direction. If I edit the text on the sheet, it could change the sheet name to match. That would be fine too...
I was wondering if it's going to be possible to populate the title block with the sheet name from drawing iProperties any time soon. I need to put a different description on each sheet for some instruction drawings. I would like to keep the entire instruction contained in one file with different sheets. I give every sheet in the browser a name that reflects the step in the assembly process, and I would like to include this name in the title block so that every sheet has de assembly step in the title block without using iLogic.
Yes, very similar to what we would like to see. This is also very handy when browsing a drawing that has many sheets when you are looking for a certain one.
One thing I would like also is the ability to "tile" or "arrange" all sheets in the drawing for a quick visual. You can do it with multiple drawings, but not within a single drawing with multiple sheets (that I know of).
Anyhow, Thank you
Chris
I've got the same problem.
I've got the rule to get the sheetname and add this to the custom properties
SyntaxEditor Code Snippet
oSheet=ThisApplication.ActiveDocument.ActiveSheet.Name iProperties.Value("Custom", "SheetName") = oSheet iLogicVb.UpdateWhenDone = True
After you run the rule you can select this in the title block by going the the custom Properties - Drawing and select SheetName
Your title block shows <SheetName> and it works.
The only problem is that you got all the same sheetname for al sheets. So the solution is to get multiple sheetnames. So for every sheet a diferent name and get this to the titleblock.
Has someone got the solution for this problem?
I've found this topic and this works for me
https://forums.autodesk.com/t5/inventor-customization/sheet-names/m-p/6827453/highlight/true#M69576
I am sure glad to report that nineteen years after somebody pointed out the absence of yet another an obvious feature intimately related to what the software does (drafting), that people are still recommending buggy macros and that Autodesk (a drafting company) has basically given up.
Autodesk is not a "drafting company". If I want drafting done, I will certainly not be hiring Autodesk to do it.
Just like any other business, they prioritize where their limited resources will be applied to best serve their customers while still maintaining a positive balance sheet. You and I may disagree with their priorities (and we do!), but our only choices are to engage with them in whatever ways they make available to customers, or to take a major investment stake in the company and try to influence priorities that way, or to find another supplier whose product does everything we want.
Your statement that Autodesk "has basically given up" implies that they have been trying to produce your desired functionality, and have failed and quit trying. I seriously doubt that you know that to be true, and if you do have that kind of knowledge about a publicly held company you're not allowed to say so in public.
Your goal in asking for this functionality is to increase the reliability and accuracy of your drawing communication, I believe. Can you not adopt the same standard of accuracy in your written communication here on the forum?
Sam B
Inventor Pro 2022.0.1 | Windows 10 Home 20H2
LinkedIn
I know this is very late to the party, but I have looked for similar functionality. I may do a drawing set of multiple sheets with views coming from an assembly (IAM) and it would be nice to be able to put into the title block what the intent of the drawing is. Instead of Drawing "1" (Sheet Number), maybe something like "Widget Installation".
An easy way to implement this would be to simply expand the "Sheet Properties" that are available in a text annotation.
Currently "Sheet Properties" (Inventor 2022) includes:
Why not add "Sheet Label" which would be whatever the "Sheet:1" is renamed to without the ":##" suffix?
Then whenever you edit the label in the tree it could be shown on the title block. You'd still have to edit the title block to access that property/parameter, so it would only affect those that want this feature.
