Inventor Forum
sheet metal
10 REPLIES 10
Message 1 of 11
simon_toaldo
716 Views, 10 Replies
sheet metal
I make this part in sheet metal.I do not do much with sheet metal tools but have i constructed this part correctly.Could i please have some feedback as the part is correct in shape but i am not sure if it is done correctly construction wise
Simon
10 REPLIES 10
Message 2 of 11
JDMather
in reply to: simon_toaldo
How will that be manufactured?
(looks to me like it should be an assembly of at least 3 parts.
The CADWhisperer YouTube Channel
Message 3 of 11
simon_toaldo
in reply to: JDMather
Yes 3 pieces.The top and bottom cut to shape and the centre piece bent to shape and all 3 put together.How would you create these 3 pieces in sheet metal and then assemble.Could you if possible show your solution.
Appreciated
Simon
Message 4 of 11
simon_toaldo
I had a look at the part today on  a fitting and it looks like it is 1 piece.Does this seem possible.It looks like it was 1 piece and then folded to shape.This is a learning exercise for me so any help appreciated
Simon
Message 5 of 11
JDMather
Simon
It must have some seams (Rips) that were welded together or it is a deep drawn deformed part.
If it has welded seams - indicate where those are.
If it is deep drawn - that is not a folding manufacturing process and Inventor will not develop the blank.
Message 6 of 11
simon_toaldo
please see attached picture.There is 3 pieces.The weld will be along the 2 edges of piece 2.How can this be done in assembly please
simon
Message 7 of 11
simon_toaldo
I`m interested to see how this would be made in assembly.Could someone with much more experience them me show me how they would do this.
Regards
Simon
Message 8 of 11
IgorMir
Hi Simon,
Something like the attached should give you an idea.
Best Regards,
Igor.
Web: www.meqc.com.au
Message 9 of 11
simon_toaldo
Hi Igor
Thanks for the model.Appreciated
Would the next step be to weld the edges?
Regards
Simon
Message 10 of 11
IgorMir
Hi Simon,
Yes, it would. But not in Inventor. In real life instead. I could never fully understand why would it be necessary to actually show the welds on the model. What's wrong with just indicating the welds on the drawing, as in good old days?
Igor.
Message 11 of 11
simon_toaldo
Thanks Igor ,, much appreciated
Simon
