Can this part be made with sheet metal tools...it will be made from aluminium..
i attach the shape made with standard tools and the sheet metal attempt.......how do add the sides in sheet metal
Regards
Terry
Inv-2013
Solved by JDMather. Go to Solution.
Here is a quick example. (you didn't have any bends or rips (corner seams)), so it was hard to tell what you are after, this might get you started)
You might have to alter your design a bit.
That is a good starting point for me.Thanks
How would you cut 4 slots across by 6 slots down.Slot size would be 2mm x 4mm
How would you cut out the slots ?
What slots?
I didn't see any in your files.
Project Flat Pattern and Cut Across Bend
or
Unfold, Cut, Refold.
