Inventor General
drafter
Message 1 of 13 (197 Views)
sheet metal ??
197 Views, 12 Replies
12-15-2011 09:42 AM
I need to know how to take a know length of material and bend the entire thing into an arc with a radius of 16.75, and I need to know how to do this in inventor so I can generate where the bend points are so we can bend it in a press break.  If anyone can help asap that would be greatly appreciated.
JDMather
Message 2 of 13 (182 Views)
Re: sheet metal ??
12-15-2011 10:09 AM in reply to: drafter
Can you create the part using stardard tools in finished form (sounds pretty simple) and attach here so that someone can demonstrate how to do the same part with sheetmetal Fold (or other technique as appropriate).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Curtis_Waguespack
Message 3 of 13 (181 Views)
Re: sheet metal ??
12-15-2011 10:10 AM in reply to: drafter
Hi drafter,
I think the Fold tool in the Sheet Metal environment is what you're looking for in this case. Attached is an example. Keep in mind that your material thickness (Extrusion thickness in my example) needs to match the sheet metal Thickness parameter to get this to work.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Member
dennymet
Message 4 of 13 (174 Views)
Re: sheet metal ??
12-15-2011 11:00 AM in reply to: drafter
Are you going to be step bending this?
Ironically, I just answered a very similar question on the SolidWorks forum:
https://forum.solidworks.com/message/264621#264621
Not sure if you can read that or not.
Autodesk Product Design Suite 2012 Premium
SolidWorks Premium 2011 SP4.0, Windows 7 Ultimate 64bit SP1
Gigabyte GA-Z68XP-UD5, Intel Core i7-2600k @ 4.66 GHz (103.5 X 45)
Corsair Vengeance 16GB (4 X 4GB) DDR3 1600
EVGA GeForce GTX 580 3072MB 384-bit GDDR5
Patriot Wildfire 120GB SSD, WD VelociRaptor 600GB 10k RPM HDD
Valued Mentor
coreyparks
Message 5 of 13 (172 Views)
Re: sheet metal ??
12-15-2011 11:15 AM in reply to: drafter
Something like this?
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
IV2014 Factory Design Suite Ultimate
Windows 7 64 bit
Synergis Adept document management software
16gb RAM --- Nvidia Quadro 4000 2gb
drafter
Message 6 of 13 (161 Views)
Re: sheet metal ??
12-15-2011 11:37 AM in reply to: dennymet
Yes I will be step bending
Member
dennymet
Message 7 of 13 (150 Views)
Re: sheet metal ??
12-15-2011 12:01 PM in reply to: drafter
Inventor isn't going to dictate the bend locations for you persay... that's something you're going to have to provide to Inventor. If you want to model each and every bend, that's not difficult but time consuming. If you want to just have a model as a representation with a constant radius bend, that's simple.
Read that thread on the link I provided, the same situation applies to both software packages.
Valued Mentor
coreyparks
Message 8 of 13 (147 Views)
Re: sheet metal ??
12-15-2011 12:03 PM in reply to: dennymet
So what I posted isn't what you're looking for?
Corey Parks
Windows 7 64 bit
drafter
Message 9 of 13 (137 Views)
Re: sheet metal ??
12-15-2011 12:55 PM in reply to: coreyparks
yes this was the best solution for my application, I took your drawing and was able to modify it to fit my needs.  The only thing I was Inventor could do that I have not found that your are able to do is constrain an arc length.  I had to keep switching back and forth from the drawing which had the flat pattern to see how close I was in the length, then go back to the part and modify it then switch back so on and so forth.
drafter
Message 10 of 13 (135 Views)
Re: sheet metal ??
12-15-2011 12:59 PM in reply to: drafter
The only other question I have for this feature is if you can put a square hole in the middle of the part before you bend it.  Reason I ask is I know the dimensions of the hole that needs to be there, so I tried adding it, but it wont let me add it unless I am in the flat pattern, but I would like for it to generate the hole before it gets bent.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
