sheet metal plate 2013 part attached...i need to bend the plate where the line is sketched...which tool do i use to make bend on the line
Trent
AIV2013
Solved by jletcher. Go to Solution.
If you use the Fold method rather than modeling "as-folded" be sure to check that your finished dimensions are what you intended. (see last few posts in this thread) http://forums.autodesk.com/t5/Autodesk-Inventor/Bend-allowance/td-p/3637050
