Inventor General
Valued Contributor
Message 1 of 9 (243 Views)
sheet metal part
243 Views, 8 Replies
12-20-2012 05:49 AM
Hi
How do i make the attach file as a sheet metal part?It takes a lot of  moves to make as solid part..can it be made in sheet metal?
Regards
Simon
Valued Mentor
japike
Message 2 of 9 (231 Views)
Re: sheet metal part
12-20-2012 06:19 AM in reply to: simon_toaldo
You should be able to make this as a sheetmetal part. Start in the sheetmetal environment and instead of using extrude as your first feature, use the face tool. Instead of extrusion 2, use a cut. You could also use the face tool with the bend option to replace extrusions 5 & 6. Give it a try. When you get stuck, post what you've accomplished here and someone will help you out.
Peace,
Jeff
Inventor 2013
Valued Contributor
Message 3 of 9 (191 Views)
12-21-2012 03:01 AM in reply to: simon_toaldo
I got to this point to sheet metal part.What steps should i now take to complete the rest of the part?
I am not sure how to create the sections which are bent
Appreciated
Valued Mentor
japike
Message 4 of 9 (182 Views)
12-21-2012 04:46 AM in reply to: simon_toaldo
Take a look at the attached file. It may give you some ideas.
Peace,
Jeff
Inventor 2013
Valued Contributor
Message 5 of 9 (178 Views)
12-21-2012 05:13 AM in reply to: simon_toaldo
Thank you,
Through your technique i made the next step but need help adding the last part to this.
CAn this when finished be flattened
Appreciated your help
Valued Mentor
japike
Message 6 of 9 (173 Views)
12-21-2012 05:29 AM in reply to: simon_toaldo
It will if you can keep the top of face4 straight. See the attached file.
Peace,
Jeff
Inventor 2013
Valued Contributor
Message 7 of 9 (166 Views)
12-21-2012 05:42 AM in reply to: simon_toaldo
I added the last piece.Is this how you would have added this curved piece?
Thank you
Valued Mentor
japike
Message 8 of 9 (163 Views)
12-21-2012 05:51 AM in reply to: simon_toaldo
Yup, looks good except sketch8 needs to be fully constrained.
Peace,
Jeff
Inventor 2013
Valued Contributor
Message 9 of 9 (155 Views)
12-21-2012 05:54 AM in reply to: simon_toaldo
Thanks for your help Jeff
Merry Christmas
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
