Hi p.panther,
Can you provide more details about your question? It's not clear from what you've posted so far.
I hope this helps.
Curtis
HI CURTIS, THANKS FOR YOUR RESPONSE, MOST OF MY WORK IS IN SHEET METAL
AND I LOVE THE SHEET METAL MODULE THERE ARE ONLY THREE THINGS TO MAKE
IT PERFECT FOR ME . WHEN YOU MAKE CUTS ACROSS BENDS OR CURVES AND UNFOLD
YOU HAVE THE CUT OBLIQUE THROUGH THE METAL. AS MOST CUTS,HOLES ARE PUNCHED THE CUT
IS NORMAL TO THE SHEET, WHICH MEANS YOU CAN,T ATTACH A FLANGE TO AN EDGE THAT IS NOT NORMAL, ALSO SOMETIMES WHEN YOU UNFOLD AND THEN REFOLD THE MODEL IS RETURNS TO A DIFFERENT PLANE, AND TO ABLE TO MULTI-PART IN SHEET METAL WOULD BE A BONUS
THESE POINT ABOVE ARE ONLY MINOR GRIPES AS A SHEET METAL WORKER/DESIGNER FOR 40 YEARS NOW, HAVING INVENTOR HAS MADE MY JOB A DELIGHT AGAIN
THANKS
PHIL
P.S THIS IS MY FIRST VENTURE INTO THE DISCUSSION GROUP
EXCUSE ME IF I WAFFLE (GO ON A BIT)
Can you attach example files here? There might be existing solutions or easy "work-arounds".
@p_panther wrote:
MOST CUTS,HOLES ARE PUNCHED THE CUT NORMAL TO THE SHEET
WHICH MEANS YOU CAN,T ATTACH A FLANGE TO AN EDGE THAT IS NOT NORMAL,THESE POINT
Are you familiar with the sketch Project Flat Pattern and the Cut - Across Bend techniques?
Hi JD
The need of normal cut is must for sheet metal design
If you see the capture the cut #1 the line is straight but i can't attach flange because the cut is non-perpendicular
#2 i used cut across the bend and i use a straight line sketch and the resut is not a straight line like #1
#3 is another sheet metal cut that is useless
#4 is workaround to avoid non-perpendicular edge
when we design sheet metal we can't always skething on the face that i would cut and that's why the need of real normal cut
Alibre(cad software for less 1000$) can do real normal cut in one feature
FROM READING DISCUSSIONS HERE IT SEEMS AUTODESK DON'T SEE THE NEED
TO INCLUDE A NORMAL CUT OPTION, I'VE GIVEN UP WAITING, JUST CARRY ON UNFOLDING, PROJECTING
UNWANTED EDGES,CUTTING AND REFOLDING- (ARGH LIFES NOT SO BAD AFTER ALL)
PHIL
Gerald,
As an employee of a sheet metal job shop, I agree with several of Phil's wish-list items:
RT
I derived components to build complex sheet metal parts and it works fine. Multibody solids are not always the best way to go about building the model, BTW. The master file can get pretty complicated at times.
Best Regards,
Igor.
@rptandy wrote:
Multibody sheet metal parts - I can't TELL you how many times I have wished for this! Every time I have a complex part that must be made in multiple pieces due to size or forming capabilities, I have to get real creative. Separate parts that have to meet at a mitred corner... they give me nightmares.
RT
SolidWorks, Solid Edge, and Pro Engineer all have Normal cutout tools in sheet metal. As a fabrication shop, losing this functionality when switching to Inventor has been my #1 frustration.
Can I ask an honest question, why did you switch to Autodesk Inventor? I'm a long time user and for the most part happy with Inventor, but none of our outside vendors use Inventor, almost all of them have a seat of SolidWorks.
All viewers of this chain please visit THIS post in the Inventor IdeaStation and give kudos. The outstanding Inventor deficiency of no normal sheet metal cut needs continued visibility with Autodesk.
Hi
To all you inventor sheet metal modual users,
Have mentioned a few times here adout cut normal still missing
so will say no more here about that.
Another problem l find is the lack of accuracy when unfolding developments using edges
From say included 3d lines from helix curves or projected cuts they can be up to 2 percent from where they should be
You have to use lofted surface and thicken and off set to get unfold to work and k factor have no affect
Thought I must be messing up somewhere so modled the same parts on a mates solidworks and they was accurate to
3 places. Its a shame you can't always trust your flat pattern without carefully checking and trying to get a closer fit to that required. There must be something in the unfold algorithm that in some cases gives increasing errors as the flat
Pattern. Wonderer if anyone else as noticed the error as well as the unfold - refold problem where the model refolds to a different plane.
Inventor still rock , we all have flaws
