Inventor General
blair
Message 11 of 20 (239 Views)
Re: shape
12-12-2012 08:51 AM in reply to: tborland
Leave it with me for a while, I think that this might have to be converted to a surface model and patches done to get the blend and then back to a solid.
I tried some delete face and heal, but it's hung up my system.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Valued Contributor
tborland
Message 12 of 20 (219 Views)
Re: shape
12-13-2012 03:56 AM in reply to: blair
Greetings Blair
I would truly appreciate the model when you do get a chance.Surfaces is 1 tool i would like to learn
Best Regards
Tony
Valued Contributor
tborland
Message 13 of 20 (202 Views)
Re: shape
12-17-2012 03:19 AM in reply to: blair
Hi
I attempted to create this shape with surfaces.Having not done before this is as far as i can go at this point...is this how you are going to create the shape with surfaces?
It would be nice to get this hape correct.
Thanks again
Valued Contributor
tborland
Message 14 of 20 (183 Views)
Re: shape
12-18-2012 05:16 AM in reply to: blair
Hi Blair
Just a quick question
1. Was the attached surface model how you would make the model?
2. Will you be able to post your attempt anytime soon
Thank you
blair
Message 15 of 20 (170 Views)
Re: shape
12-18-2012 08:23 AM in reply to: blair
I haven't even had time to look at doing anything on this (some of us work 6 days a week and do this to fill in the remainder of the time).
You should be starting to coil the other way. You will still have a problem with the transition of the "Feed Tube" into the body. Either this needs to have a pitch (increasing in radius) or the center of the "Feed-Tube" can't be at the same point as the center of the body.
Win7-64
Valued Contributor
tborland
Message 16 of 20 (152 Views)
Re: shape
12-19-2012 04:32 AM in reply to: blair
Hi Blair
Yes i appreciate any help you offer.....you guys are generous in devoting your time with help.....i will just keep checking back just in case you may find some time.If not i understand you are too busy
Best Regards
TB
Valued Contributor
tborland
Message 17 of 20 (136 Views)
Re: shape
12-20-2012 06:00 AM in reply to: tborland
Here is the section i am having trouble creating....is this for surfaces to get the correct appearance?
Valued Contributor
tborland
Message 18 of 20 (122 Views)
Re: shape
12-21-2012 05:29 AM in reply to: blair
I made a little further progress.I would sure like some help with this.If i can get the throat section correct the rest i can finish..I am not familiar with surfaces but i have tried to use for this section but ubfortunately do not know how to get it to look like the picture attach..
Can someone help with this section so as to create like in the picture
Thanks alot
Tony
Valued Contributor
tborland
Message 19 of 20 (109 Views)
Re: shape
12-21-2012 02:37 PM in reply to: blair
Is there any reason why i cannot get any help on this part (surface part - picture included)...maybe i should just forget asking
I understand and appreciate any help but i see other post getting help which are no more dificult then this request...if it is not possible to achieve i would rather someone say and i will stop asking
Merry christmas to you all
Tony
blair
Message 20 of 20 (93 Views)
Re: shape
12-22-2012 08:07 PM in reply to: tborland
1.) When people post with files "created with educational version", people are reluctant to do the students work. This shows the tube with the proper transistion/blend into the body.
Win7-64
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
