Inventor Forum
separate 1 part into multiple parts
3 REPLIES 3
6796 Views, 3 Replies
attached is a basic IV2012 part made as 1.....can i separate the 2 features and make 2 independant parts from the single part?
If yes can i then use these separate parts and place in assemblies?
Cheers
Terry
3 REPLIES 3
Curtis_Waguespack
Hi Terry__Close,
When you create the features as seperate solid bodies you can use the Make Components tool to derive out each solid body as part files and have them placed into an assembly. To find the make components tool go to the Manage tab.
I hope this helps.
Curtis
JDMather
Edit the Revolve feature and select the New Solid Option.
Then on the Manage tab select Make Components to push out to individual part files.
in reply to: JDMather
Thank you,
Terry
