Inventor General
Valued Contributor
Terry__Close
Message 1 of 4 (603 Views)
separate 1 part into multiple parts
603 Views, 3 Replies
04-04-2012 07:22 AM
attached is a basic IV2012 part made as 1.....can i separate the 2 features and make 2 independant parts from the single part?
If yes can i then use these separate parts and place in assemblies?
Cheers
Terry
Curtis_Waguespack
Message 2 of 4 (590 Views)
Re: separate 1 part into multiple parts
04-04-2012 07:29 AM in reply to: Terry__Close
Hi Terry__Close,
When you create the features as seperate solid bodies you can use the Make Components tool to derive out each solid body as part files and have them placed into an assembly. To find the make components tool go to the Manage tab.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Message 3 of 4 (589 Views)
04-04-2012 07:30 AM in reply to: Terry__Close
Edit the Revolve feature and select the New Solid Option.
Then on the Manage tab select Make Components to push out to individual part files.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Valued Contributor
Terry__Close
Message 4 of 4 (568 Views)
04-04-2012 08:27 AM in reply to: JDMather
Thank you,
Terry
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
